DodgeFreak wrote:you don't have to use the newer filter and i wouldn't because its going to suck the same amount of fluid as before but if its up higher it won't suck as much junk.....we're running a b&m pan and i've used the filter extender and with out and there is no difference....just as to where it places the filter, you still fill it to the same level as before.
dunes450r wrote:http://www.amazon.com/Derale-14210-Transmission-Cooling-Dodge/dp/B004XONSYE
this is the pan that i had. worked great, lowered temps, increased capacity, and was relatively cheap compared to a mag hytec or the like
ellis93 wrote:Not saying that you would but under hard cornering or extreme take off you could cause the pump to loose prime,from there Al sorts of nasty stuff can happen from there. Time will tell
Diesel wrote:dunes450r wrote:http://www.amazon.com/Derale-14210-Transmission-Cooling-Dodge/dp/B004XONSYE
I would buy that pan outright if they would set aside their gimmick marketing scheme. I just can't bear to have a deep transmission pan with tubes running through the pan...and the tubes have spirals in them to spin the air...
I'd sooner install a tornado air management system and a KN dirt injection filter...
dunes450r wrote:Diesel wrote:dunes450r wrote:http://www.amazon.com/Derale-14210-Transmission-Cooling-Dodge/dp/B004XONSYE
its not really a gimmick......but whatever. its the same idea as a finned pan, and it did cool my trans temps. your loss.
and if your smart enough to oil a k&n regularly and don't drive roads with 3" of dust everyday, they work well also.
ignorance is bliss
ellis93 wrote:There's some people needing to tear apart some lawn mower motors and look how they're cooled
DodgeFreak wrote:ellis93 wrote:There's some people needing to tear apart some lawn mower motors and look how they're cooled
Air cooled or liquid lol ....j\k
