hot od
hot od
Postby (92)cummins » Tue Oct 16, 2012 1:35 pm
will the overdrive kick out when the tranny gets prtty hot
92 w350 srw flatbed
1985 D350 crew cab diesel conversion in progress
79 w200 power wagon
93 D350 drw 5spd getrag 4 door donor
90 D350 auto(fried) flatbed
93 D250 auto
(92)cummins
Re: hot od
Postby ellis93 » Tue Oct 16, 2012 1:42 pm
Yep,temp sensor in the cooler lines
hot od
Postby (92)cummins » Tue Oct 16, 2012 1:48 pm
will the overdrive kick out when the tranny gets prtty hot i was messing around and blowing smoke on some big hills and lost od
92 w350 srw flatbed
79 w200 power wagon
93 D250 auto
(92)cummins
Re: hot od
Postby (92)cummins » Tue Oct 16, 2012 1:52 pm
K i usually baby the truck but today i let it loose, any other things it could be?
92 w350 srw flatbed
79 w200 power wagon
93 D250 auto
(92)cummins
Re: hot od
Postby (92)cummins » Tue Oct 16, 2012 3:56 pm
well its not heat that caused my od to kick out, let the truck cool down and still nothin
92 w350 srw flatbed
79 w200 power wagon
93 D250 auto
(92)cummins
Re: hot od
Postby ellis93 » Tue Oct 16, 2012 4:40 pm
Rut row......clutch pack,solenoid,or tps
Re: hot od
Postby cmann250 » Tue Oct 16, 2012 4:57 pm
Could have lost a seal. Are the other shifts more mushy than usual?
Re: hot od
Postby (92)cummins » Tue Oct 16, 2012 6:14 pm
i have the od on a switch so no tps, im gonna check on the solenoid tomorow, it still shifts strong, ill deal with it tomorow i tend to break things when i am frustrated
92 w350 srw flatbed
79 w200 power wagon
93 D250 auto
(92)cummins
Re: hot od
Postby (92)cummins » Tue Oct 16, 2012 6:15 pm
i also rebuilt the tranny about 300 miles ago
92 w350 srw flatbed
79 w200 power wagon
93 D250 auto
(92)cummins
Re: hot od
Postby ellis93 » Wed Oct 17, 2012 6:27 am
Did you measure the distance between the o/d piston and the needle bearing?
Re: hot od
Postby (92)cummins » Wed Oct 17, 2012 9:29 am
i had the tail housing rebuilt by a tranny guy so i didn't have to deal with the whoop a$$ spring
92 w350 srw flatbed
79 w200 power wagon
93 D250 auto
(92)cummins
Re: hot od
Postby ellis93 » Wed Oct 17, 2012 10:37 am
This
If the clearance isn't right you could have chewed the lip seals on the o/d piston
Re: hot od
Postby (92)cummins » Wed Oct 17, 2012 11:26 am
sweet, ill check on the selonoid then that clearence, do i have to pull the tranny to pull the tailhousing off or will i be able to do it still in the truck
92 w350 srw flatbed
79 w200 power wagon
93 D250 auto
(92)cummins
Re: hot od
Postby (92)cummins » Wed Oct 17, 2012 11:32 am
It should be ok if the splines stay aligned
92 w350 srw flatbed
79 w200 power wagon
93 D250 auto
(92)cummins
Re: hot od
Postby (92)cummins » Wed Oct 17, 2012 2:31 pm
if the clearance was wrong wouldn't it have failed right away
92 w350 srw flatbed
79 w200 power wagon
93 D250 auto
(92)cummins
