hot od
Re: hot od
Postby ellis93 » Wed Oct 17, 2012 4:05 pm
Not necessarily,if the piston travel outward just alittle to far and cause the seals to bulge just enough to stress them and have them be shaved by the aluminum housing little by little.
This is not a definite thing,could be the solenoid,you'll have to drop the pan anyhow and you'll find out which it is.
As far as removal,you could just pull the o/d section and have no problems.
Re: hot od
Postby DodgeFreak » Wed Oct 17, 2012 7:50 pm
before dropping the pan throw a pressure gauge on the od port...when our seal went out it would slowly climb to 24psi and fluctuate...... we just yanked the od and replaced the seal and clutches threw it back together. 3 years later it still works...
Re: hot od
Postby (92)cummins » Wed Oct 24, 2012 5:37 am
Well i put a new od selonoid in and it works just fine now
92 w350 srw flatbed
1985 D350 crew cab diesel conversion in progress
79 w200 power wagon
93 D350 drw 5spd getrag 4 door donor
90 D350 auto(fried) flatbed
93 D250 auto
(92)cummins
Users browsing this forum: No registered users and 69 guests
