by 90chum » Wed Oct 17, 2012 7:02 pm
I'm getting tired of the old slushbox
-I have an nv out of a 93 chev 4x4 diesel that needs a bearing under the one gear
-there is an nv out of a 98 dodge 4x4 for sale that needs 3rd and 5th gear (one broken, one stolen)
i was wondering how feasible it would be to make the swap, or if i should find a getrag, or some other auto. i have been researching it and can find a wealth of nv parts on ebay to fix it.
what i would like to do:
2nd gen pedals, hydros, bell housing, and starter if need be (have access to small machine shop and places to get hoses if needed)
a fixed nv (prefer from the chev because its free to me), proper input shaft, and anything else i can find it needs
either big single or dual disk
rebuild my np205(needs it)
so...whilst reading, i've heard: the gm nv has a different bolt pattern on the front, the auto t-case has a weaker input that wont handle behind a cummins with no torque converter and much machining is needed to put the bigger input in the 205, the 2g bell makes the starter hit the frame, something about cutting where the throwout rides, the bigger input shafts wont work in the gm
am i missing anything(parts or differences), and can anyone clarify any of this, i figured the nv's were the same except the input and it would be slam bam nv 1st gen. or should i locate a getrag? or build the 727? or a better auto?
1990 w250 RCLB auto-some stuff to make a constant haze, diamond eye 4" straight, 47rh with goerend triple disk and suncoast innerds, body panels and more panels. shes occassionally referred to as a dirty slut, but usually just chum
