A727 ==> NV4500?
Re: A727 ==> NV4500?
Postby 90chum » Wed Nov 07, 2012 1:07 pm
so just the plate then, nothing else?
1990 w250 RCLB auto-some stuff to make a constant haze, diamond eye 4" straight, 47rh with goerend triple disk and suncoast innerds, body panels and more panels. shes occassionally referred to as a dirty slut, but usually just chum
90chum
Postby tampabayBill » Wed Nov 07, 2012 1:15 pm
Starter and 3 pin connector for the od and lockup
Twins coming soon!
tampabayBill
