Tranny Cooler
Tranny Cooler
Postby nolafishr » Tue Oct 30, 2012 7:50 am
I will be reloacting my front tranny cooler from the grill area to under the front bumper area and was wondering if it matters on how the tranny lines hook up to the cooler with the flow of oil. Is there a certain way they go to the cooler on the in/out lines? I was wondering about this and wanted to ask.
nolafishr
Re: Tranny Cooler
Postby tampabayBill » Tue Oct 30, 2012 11:57 am
Doesn't matter, can you get good air flow in that position ??
Twins coming soon!
tampabayBill
