95 drivers drop tcase to 89 727 w/208
Postby BAD HABIT » Thu Nov 01, 2012 4:25 am
Will the 95s driver drop case fit the tailshaft of my 89 727, has anyone done this?
79 f150 4x4 on 44s with a 12 valve
BAD HABIT
Re: 95 drivers drop tcase to 89 727 w/208
Postby CUMMINSDODGEMAN3 » Mon Nov 12, 2012 12:34 pm
Team Green's old hauler 05 3500 CTD 4x4 6sp 8in rize industries lift, 37 Toyo M/T's, Smarty, Edge Att, AFE intake, ATS manifold Borg Warner turbo, 5in SS MBRP
90 W350 CTD SRW big pump, big turbo, lots of fuel, 47RH billet suncoast triple disc and 20's
93 D250 CTD ext cab pump work, POD's
CUMMINSDODGEMAN3
Postby Mark Nixon » Tue Nov 13, 2012 6:45 pm
Simpler would be to find a 241D from behind an '88 through '93 gasser truck and upgrade accordingly.
It's already passenger's drop AND has the benefit of being a fixed rear yoke, instead of a slipper.
Postby BAD HABIT » Sun Oct 06, 2013 7:34 pm
I have a 727 with a passenger side case, i put the motor tranny and t case in a ford, so now i need to get a driver side t case to work in my ford
BAD HABIT
Postby Mckinney » Sat Dec 07, 2013 3:45 am
The easiest way would be to use a drivers drop divorced NP205 tcase. Could be found on older fords but I don't know the exact years
Mckinney
