Auto tranny upgrades
Postby gomerpile » Sat Oct 20, 2007 4:48 am
alright i want some opinions on the hughes tc rebuild, im thinking the xfm, IIRC, its a triple disk and what can i get the stall set at? is there any better places for similiar money ($400). and the next one is the trans go shift kit, is it worth it? ($60) will it firm up shifts?
will i need a tranny cooler under the bed for towing or will this control the heat well?
lastly will this support 350+hp?
1992 Dodge D-250 LE auto, LSD w/3.54, about 200,000+ miles.Isspro Pyrometer , Sunpro tach,Tractor Supply Boost Gauge, Old Smokey Fuel Pin,4 turns on fun srew, starwheel turn CCW 1 turn, 40hp injectors, BHAF,16 cm housing.Sony Head Unit.
gomerpile
Postby Philip » Sat Oct 20, 2007 6:44 am
The trans go kit will firm up the shifts.
On the converter. I do not see anything in you sig that says you have a 47rh/618 transmission installed. If you have the stock trans it is a 518. This is not a lockup converter transmission.
Postby CAJUN 93 » Sat Oct 20, 2007 6:53 am
i'm no expert on auto's by any means but i thought the 3 disc-5 disc thing is for lock-up trans. if you still have the stock 518 you dont have lockup so the disc thing does not apply. as for the stall, get as tight as you can without bogging the truck in high gear at low rpms. talk to the guys at hughes or any other convertor shop and they'll help you get what you need.
even the cheapest shift kit will improve shift quality, and as violent as it seems the harder the shifter the longer the trans will survive. it eliminates or reduces the slipping between gears which adds wear to the clutches. most just make valve body changes that affect fluid pressure and timing to the internal components. go for it
daryl
CAJUN 93
Postby gomerpile » Sun Oct 21, 2007 4:27 am
please disregard post
stupididy got me again
gomerpile
Postby Philip » Sun Oct 21, 2007 6:41 am
That section you posted is for a transmission used in a 94 and up. In 94 Dodge went to the 47RH/618 trans. It is a lockup converter trans. Your 92 does not have the same trans. It is a 46RH/518. This is a non lockup converter.
Houghs has both trans listed on the same line on their site. But they shouldn't be.
Installing a lockup converter would do nothing for you. You do not have the hyd circuits to make it work in your trans.
Postby BC847 » Sun Oct 21, 2007 8:22 am
Philip wrote: Installing a lockup converter would do nothing for you. You do not have the hyd circuits to make it work in your trans.
Further, it plain won't fit as the '94 and up use a thicker engine/transmission adapter plate so as to accommodate the thicker converter (there's almost an inch difference).
Postby Philip » Sun Oct 21, 2007 11:21 am
I forgot about the adapter housing difference BC478.
Postby BC847 » Sun Oct 21, 2007 12:38 pm
Here's a thread where I recently overhauled/upgraded my heaps A518 like you have. In my application, I was trying to eliminate any slip from added power, and to fix a number of the well known "Internal Leaks" associated with the 727 series transmissions.
http://www.dieseltruckresource.com/dev/ ... p?t=160276
Hope this helps. :)
Postby Philip » Sun Oct 21, 2007 1:55 pm
I should have remembered it myself. I have a 47RH setting in the garage waiting for a rebuild. :D
Postby gomerpile » Sun Oct 21, 2007 2:17 pm
Philip wrote:That section you posted is for a transmission used in a 94 and up. In 94 Dodge went to the 47RH/618 trans. It is a lockup converter trans. Your 92 does not have the same trans. It is a 46RH/518. This is a non lockup converter.
alright it was the same line thing that threw me off, :oops: oops, well i had seen something on DTR of someone using a xfm in a 46RH and i thought it was the same
gomerpile
