78fordf150ranger wrote:If you where going to rebuild your A518 auto what would you upgrade and parts would you use?
cummins12club wrote:What is ur line pressure set at David?
lol stock Is 60 I believe how do u adjust line pressure on these?BC847 wrote:cummins12club wrote:What is ur line pressure set at David?
Dunno. I kept turning it up till things quit slipping.
DZL_Damon wrote:EDIT: Please note that recent information has cleared up how much line pressure will change with each turn. I was told 2.5-3psi per turn. I assumed he meant full turns, apparently he meant the amount of turns your are able to do with the valvebody in the tranny (which is about 1/4 turn). So 2 full turns will jack the pressure up about 25 psi I've been recently told. I have not heard back if this is too much or not, but he did say you don't want to go above 150psi total. Since the stock setting is 90-96psi at 1600psi with the TV cable all the way back, I'm guessing I'm approaching that maximum with 2 full turns.
cmann250 wrote:DZL_Damon wrote:EDIT: Please note that recent information has cleared up how much line pressure will change with each turn. I was told 2.5-3psi per turn. I assumed he meant full turns, apparently he meant the amount of turns your are able to do with the valvebody in the tranny (which is about 1/4 turn). So 2 full turns will jack the pressure up about 25 psi I've been recently told. I have not heard back if this is too much or not, but he did say you don't want to go above 150psi total. Since the stock setting is 90-96psi at 1600psi with the TV cable all the way back, I'm guessing I'm approaching that maximum with 2 full turns.
