if you where going to rebuild your A518 what would upgrade?
Re: if you where going to rebuild your A518 what would upgrade?
Postby txs » Wed Dec 19, 2012 6:43 pm
the kickdown lever needs to go towards the rear of the vehicle, that is wide open throttle position. 150## maximum, 1600# must be misprint. I wouldn't go that high in a daily driver. harder on the seal rings.
txs
Postby MMiller » Fri Dec 21, 2012 9:26 pm
If I was going to rebuild my 518, I would upgrade it to at least a 47rh to get a lock up convertor. I currently have a 518 in my crew that has a "diesel" convertor that feels really tight when you are trying to sit at a stop light and feels really good until about 40 mph. After that it feels like I can drive through the convetor at will.
Take everything I say with a grain of salt. I use my pickups to pull heavy loads, and prefer rowing my own gears. The 518 will not stay forever in my crew.
Michael
MMiller
