by MMiller » Fri Dec 21, 2012 9:35 pm
You did not replace the cluster that meshes with the input gear? Of all the failures I've repaired in the Getrag, the input gear is not one of them. Check and make sure the countershaft bearing races do not move around in the case. I had one that the bearing spun in the case, making the bore too large, and then the countershaft could move up and down. It had failed twice, in low miles, and was repaired by two other shops before I found the bad case. That could cause improper mesh with the input gear.
