Getrag cluth problems
Re: Getrag cluth problems
Postby bmoeller » Mon Dec 31, 2012 3:08 am
Had a SB Con-O in the 92 I had. Worked great! :) Doesn't engage as smooth as a stocker, so i had to re-learn the best way to drive it, vs the stocker in my 99.
IIRC, SB does use some Valair stuff too.
The flywheel MUST be turned at a machine shop! Need to factor turn around time in the clutch job. Could be same day, or longer.
I recommend a new rear main seal while the trans is out. You are in there already, might as well. Won't have to worry about it leaking on your clutch later.
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Postby Bob L » Mon Dec 31, 2012 10:23 am
Excellent suggestion on the rear main seal. I replaced mine when replacing the clutch.
I would not even think about not replacing the rear main seal.
I also completely rebuilt the Getrag 360 at the same time.
Result, better than new !.
Another thing to consider is U-joints ?. Of course if your trans and U-joints are good then rear main & clutch is all you need.
Bob L
NRA Life Member 1974
'92.5 D250 LE EXT.CAB...Getrag...All Original...No Rust...
Purchased new in late Oct.'92---128K Mi. Still Like New.
Bob L
Postby Bob L » Mon Dec 31, 2012 10:36 am
Forgot to add---
I went with NEW flywheel (oversize) which included heavy duty oversize pilot bearing, and of course a new thro-out bearing. Like bmoeller said you might as well do it all at the same time as long as you're in there anyway. Why take a chance of having to do it over. I don't know about you but down time is a killer for me.
I know it's a lot to consider. Best of luck.
Bob L
Bob L
Postby 93MikeB » Mon Dec 31, 2012 9:21 pm
Beings that it's my daily driver and only source of transportation, downtime is a big deal for me :lol:
93MikeB
Postby Bob L » Wed Jan 02, 2013 11:20 am
Heads Up 93MikeB:
Here is a good link for part number and installation of the rear main seal.
http://www.dieseltruckresource.com/dev/ ... p?t=202854
You may have to copy and paste. Sorry
VERY IMPORTANT--- Be sure the surface is DRY & CLEAN before installing new seal. Use BrakeClean....No residue.
When I did mine the local Cummins shop had 5 seals in stock. I was going to buy 2 just in case I spoiled one, but the local Cummins shop is so close to me that opted for one. First one worked good for me. I am sure it will for you too.
Bob L
Bob L
Postby JD91 » Mon Jan 07, 2013 10:49 pm
ive got a valair single disk on my 93 d350 daily drivin work truck and i pull trailers almost everyday ...no complaints, love it
91 w250 RC, getrag, 4in turbo back diamond eye
93 D350 CC, getrag, 4in diamond eye, 60# springs,3200 gov,arp's,fass 150,fass sump, BD SUPER B 58MM, 5x14 sticks, M&H timing spacer, cut fuel pin,valair clutch, auto meter pyro & boost......she screams!!
91.5 d350 RC, getrag, cut fuel pin, no bed lol "the beater"
75 dodge club cab swb flat bed 4x4 "gasser" on 37's
JD91
Postby Rusnak12 » Tue Apr 02, 2013 12:26 pm
don't forget to check crankshaft endplay as well. since thrust bearing wear is a big issue with manual shift trucks. especially if ur over 150k. idk the spec off hand but im sure I could find it in my mess of papers in the garage. and I used a Luk 13" with a new flywheel, a needed upgrade for the 13", on my truck
Rusnak12
