518 tube/dipstick on 47rh?
Postby rcb » Thu Feb 07, 2013 7:46 am
I know the transmissions are very similar, would the dipstick/tube be the same for either?
rcb
Re: 518 tube/dipstick on 47rh?
Postby tampabayBill » Thu Feb 07, 2013 7:56 am
I used the 518 tube and dipstick on my 47rh, works great no problems.
Twins coming soon!
tampabayBill
Postby rcb » Thu Feb 07, 2013 1:23 pm
Thanks! I was thinking as much. I kind of wish I had read some of the threads on here about just converting the 518 to a locker... but I've already rebuilt this one and beefed it up a tad, and I have OD as well. Still....
rcb
