ellis93 wrote:Ya if the coil dies in the solenoid it'll kill it dead and you'll have to gut it.
dazedandconfused wrote:Pump is turned up to far with stock injectors. Those little rubber pieces are stuck in your delivery valves more then likely. Turn the power screw out a turn or two and you will stop killing fss I bet.
jack wrote:Do not throw any thing suppose if problem not solved after doing that so what you will do that i suggesting you go to garage or car care center to fix the problem.
