Transmission problems OR Rear end problems
Postby bigpapad150 » Sun Feb 17, 2013 10:41 am
How do you tell ???
When i get on the expressway I can't get over 55 miles an hour.
My truck starts drinking gas.
I think my transmission has O/D.( not working ???)
OR
Is it the rear end ??????
bigpapad150
Re: Transmission problems OR Rear end problems
Postby dazedandconfused » Sun Feb 17, 2013 10:46 am
Give us specs on the truck. Engine, transmission, tire size and gear ratio if you know it along with rpm at certain speed.
Postby bmoeller » Wed Feb 20, 2013 3:24 pm
Could be a fueling problem, or a fan clutch that is stuck on as well. Need more info. could be anything at this point.
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Postby dazedandconfused » Wed Feb 20, 2013 3:35 pm
His truck is a gas halfton i do believe.
Postby bmoeller » Wed Feb 20, 2013 4:34 pm
If its a gasser, are the nuts for the carb tight? BTDT on an old Mazda B2000. Every time the screw came loose, no power! :lol:
bmoeller
Postby PToombs » Wed Feb 20, 2013 6:30 pm
dazedandconfused wrote:His truck is a gas halfton i do believe.
Well that explains it! If it had a Cummins it would go like hell! ;)
