OD issues
OD issues
Postby coolhand_luke » Wed Mar 27, 2013 9:12 pm
Hey guys I have been experiencing some transmission issues. In the morning on the way to work, before the truck is all the way warmed up, the tranny will shift in and out of OD while going highway speeds. it does it 5 or 6 quick times in a 10 or so seconds and thats it. The tranny is also shifting late too at all times. Thanks for any help
coolhand_luke
Re: OD issues
Postby Mark Nixon » Thu Mar 28, 2013 7:31 am
As far as the O/D issue, check the TPS, if it still has one.
If it does, do the POT conversion.
You may also want to check the adjustment on the TV cable for the late shifting.
Re: OD issues
Postby coolhand_luke » Thu Mar 28, 2013 8:19 am
So the tps could be going bad? I'm not familiar with the pot conversion.
coolhand_luke
Re: OD issues
Postby Hansen01 » Thu Mar 28, 2013 8:39 am
Under construction...
Hansen01
Re: OD issues
Postby Mark Nixon » Thu Mar 28, 2013 8:41 am
It's called a potentiometer, actually.
It replaces the TPS with a dash-mounted knob that you can set to your liking, rather than depend on the TPS, which can be really spendy to replace.
I think there's a couple of write-ups over on DTR for the POT conversion.
Re: OD issues
Postby coolhand_luke » Thu Mar 28, 2013 10:42 am
Thanks, Bd which cable is the TV cable?
coolhand_luke
Re: OD issues
Postby cmann250 » Thu Mar 28, 2013 11:17 am
coolhand_luke wrote:Thanks, Bd which cable is the TV cable?
If you don't have cruise control, it's the only cable on the throttle bracket. Otherwise, the TV cable goes down to the driver's side of the transmission.
Re: OD issues
Postby Diesel » Sun Mar 31, 2013 7:38 pm
You can replace the tps with a cheaper replacement so you dont have to add a pot. Someone posted a different mopar sensor that works.
1991.5 D250 Intercooled A518
Diesel
Re: OD issues
Postby Dodgebob1980 » Mon Apr 01, 2013 5:07 pm
Could also be the temp sensor in the tranny line.
Dodgebob1980
