what t case will fit?
Postby BAD HABIT » Sat Apr 06, 2013 7:18 pm
Havnt done any research,figured id ask to see if anybody knew...I have a 727 with 208 t case,i need to convert it to a driverside drop for my new truck.Is there a 2nd gen 241 model with the same spline count that will bolt to it?
79 f150 4x4 on 44s with a 12 valve
BAD HABIT
Re: what t case will fit?
Postby bmoeller » Sun Apr 07, 2013 1:54 pm
Not sure on the spline count, or shaft diameter, but also need to pay attention to the input shaft length on the 241 cases as well. Some longer than others. There are also the 241 DLD and the 241 DHD.
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Postby dunes450r » Sun Apr 07, 2013 5:45 pm
is it a diesel 727?
IIRC all cummins automatics up til 03 (maybe?) had 23 spline outputs with a coupler and the t-case has a male 23 spline input
dunes450r
Postby bmoeller » Sun Apr 07, 2013 6:18 pm
241 has a FEMALE input and no coupler.
bmoeller
Postby ihredneck » Wed Apr 10, 2013 6:32 am
The 241 came in several configs as bmoeller said.
23, 29, 31 & 32 spline input shaft
The input shaft also had 2 different lengths depending on the auto or manual transmission application
As far as diameters, I'm not sure?
The bolt pattern on the input side to fasten it to the tranny are the same on all of the 241's though
ihredneck
Postby BAD HABIT » Sun Oct 06, 2013 7:39 pm
So ill try a driver side 241 from a 1/2 ton and see if it fits, trial and error i guess, when i pull it apart ill count the splines
BAD HABIT
Postby Mckinney » Sat Dec 07, 2013 3:32 am
Keep us updated. I'm curious as well
Mckinney
