getrag problems
getrag problems
Postby Dodgecrawler2011 » Sat Apr 13, 2013 9:01 pm
92 5 speed 4x4. Tranny has typical finesse to find gears. But after a long drive in 5th empty. Its hard almost impossible to find any gear. Also in second at a low speed and very little throttle something is very clunky idk if its in t case or tranny.
Dodgecrawler2011
Re: getrag problems
Postby PToombs » Sun Apr 14, 2013 3:48 pm
Is it full of oil? Or overfull? These trannys live longer if they are 1 qt over factory full. It sounds like the bearings are getting loose. Pull the PTO covers and see if there is any end play in the shafts. If so, it may need a rebuild. By the time you realize it's loose it's usually too late and needs a rebuild.
Re: getrag problems
Postby ellis93 » Sun Apr 14, 2013 4:57 pm
This^
And maybe your top cover is screwy
Re: getrag problems
Postby Dodgecrawler2011 » Sun Apr 14, 2013 7:47 pm
I was told by po he overfilled it witb full synthetic. But im goin to change here in a bit. And my top cover is screwy sometimes. 95% of the time it shifts like butter
Dodgecrawler2011
Re: getrag problems
Postby Dodgecrawler2011 » Thu Apr 18, 2013 3:48 pm
I been having more problems still and beem looking around seems like the alignment screws could be wore out? Does this sound right. 5 th is only gear it does in. Shifter acts like its in neutral but tranny is Still in 5 th u gota try and wiggle it around in the 5th and reverse area. And it feels good again until you put in back in 5 th
Dodgecrawler2011
Re: getrag problems
Postby ellis93 » Thu Apr 18, 2013 4:16 pm
Could be the pins,one way to know for sure is to pull the shifted stub and look at them. Also pay attention to the end of the stub,make sure its not worn off.
Re: getrag problems
Postby Dodgecrawler2011 » Thu Apr 18, 2013 4:36 pm
Is there pose to be nylon on the end of the stub? It dont loom real bad. And the po had bit a different top plate on it. Idk if he was old or if it was a rebuilt one im not sure
Dodgecrawler2011
Re: getrag problems
Postby ellis93 » Thu Apr 18, 2013 6:11 pm
All I've seen is steel on the end,kind of a flat blade screw driver end.
Re: getrag problems
Postby Dodgecrawler2011 » Thu Apr 18, 2013 6:23 pm
So how can I tell if its wore out then. Is there a thickness it should be
Dodgecrawler2011
Re: getrag problems
Postby ellis93 » Thu Apr 18, 2013 6:28 pm
Pull it and snap a pic,several of us should be able to tell. Plus you'll see signs of wear on it,maybe a step worn on it thats not suppose to be there....that kinda thing
Re: getrag problems
Postby Dodgecrawler2011 » Thu Apr 18, 2013 8:37 pm
Ok ill see what I can do. Also I seen on ebay a shifter stub that comes with the screws and all that amd comes with 2 c clips? Mine only has one. Should there be two?
Dodgecrawler2011
Re: getrag problems
Postby Mark Nixon » Fri Apr 19, 2013 12:56 pm
I'm going to go out on a limb and say it's time to do bearings, syncros and an input, at LEAST.
You may get into needing forks and rail bushings, too.
There's only 1 C-clip to hold the shifter in.
That seller on Ebay is a screwball. :lol:
He has the early 1992-1993 Dodge GAS NV4500 shifter stubs listed as fitting the '94-'97 trucks and he is dead wrong, but he'll find out soon enough when he gets bad feedback for selling people the wrong part. ;)
Re: getrag problems
Postby Dodgecrawler2011 » Sat Apr 20, 2013 8:27 pm
Heres a picture that would actually work
Dodgecrawler2011
Re: getrag problems
Postby redneckmtrsprts » Tue Sep 17, 2013 8:00 pm
mine was getting screwy pulled my shifter and the end was wore bad so I did some fabrication on it and now its been holding prefect and no problems what so ever
redneckmtrsprts
