dazedandconfused wrote:My thoughts are the 518 sucks lol. Mine could use a rebuild but I'll put that money into my 47RH.
ellis93 wrote:With the exception of the converter,the rebuild is gonna cost you the same thing....almost the same if not the same parts.
I know,I know.....block plate,starter bla bla bla......you've already did it once why not do it again and have zero regrets. Only this time you could use the pressure switch thing(like I am) to actuate the lockup and od with toggle switches wired in between. Just food for thought.
BC847 wrote:Ya gotta pay to play,
- How quick do you want to go? $$$
txs wrote:If you need assistance when you go through whatever you decide to put in, let me know, neighbor. If you go with a 518 and make it a lockup do get an alloy input, i've seen a couple stock motors break one and its ugly, takes out the whole pump assembly. Are you 2x or 4x4, cant remember. Ive got a 2 wheel drive 518 in a 92 6bt donor truck you can have for help pulling the motor and tranny.
RCCUMMINS89 wrote:Especially being a puddle sniffer as it is.
