new guy with problem
Postby sweetdreamz » Thu May 16, 2013 9:33 am
I own a 1996 2nd gen truck with 47re auto, apparently the previous owner blew the motor and dropped in a 1st gen ve pump motor. Problem I am having is the kickdown cable to control the pressure in tranny. How do I connect a 2nd gen kickdown cable for a 47re to a ve pump throttle assembly??????? Help or links would be greatly appreciated.
sweetdreamz
Re: new guy with problem
Postby cougar » Thu May 16, 2013 10:02 am
This is how a stock intercooled linkage set up looks. The cable closest to the engine is the cruise control. The one in the middle is the kick down or "TV" cable. The outboard is the throttle.
01 2500 "the work truck".
cougar
Postby cougar » Thu May 16, 2013 10:24 am
cougar
Postby sweetdreamz » Thu May 16, 2013 11:11 am
I have no bracket, and 47re is a pull type not push cable
sweetdreamz
Postby cougar » Thu May 16, 2013 12:03 pm
You will need to change the transmission end of the TV cable so it becomes a push cable like this
1st and 2nd gen TV cables are different. The second gen does a 180° as seen in the above link. You will have to fab a bracket on the transmission to turn the cable back around. If your hoping for a bolt on solution there isn't one that I know of.
cougar
Postby rockbuggy4x4 » Fri May 17, 2013 7:53 am
Would a 1st gen TV cable fit in place of the 2nd gen? With addition of a bracket or two?
Jimmy
--> '95 jimmy not so stock
rockbuggy4x4
Postby cougar » Fri May 17, 2013 8:46 am
You may need to replace the arm the cable attaches to to a 1st gen arm. Different length and clocking.
cougar
Postby sweetdreamz » Wed May 22, 2013 5:13 am
Well, I ended up having a buddy fab up a new bracket and rod to connect to the TV cable on the other side of pump. Works fine.
sweetdreamz
