Keeping my auto alive?'s
Postby 93 W350 LE » Mon May 27, 2013 8:09 pm
So I am doing the free do it yourself tweaks to the engine, creating more power. How do I safe guard my trans from a premature death. My truck is a 93 W350 CCLB. It has a Banks Power pack including exhaust, I have turned my fuel pin and bottomed the star nut, smoke screw in 1/2 turn, it also has a GearVendors over/under drive unit. It is my daily driver and hauls my 14k lb 5th wheel. Could potentially have to haul 1/2 way across the country, from SW Fla to Mo or Ok.
Any info or tips are appreciated.
Eric
93 W350 LE
Re: Keeping my auto alive?'s
Postby dunes450r » Tue May 28, 2013 8:43 pm
fresh fluid/filter, shift kit, tighten/adjust the bands and shift points, deeper pan, bigger cooler, tighter converter.
do all the free/simple/cheap ones: fluid/filter change, adjust bands and shift points and add a shift kit at least, the other things will help even more
dunes450r
Postby CumminsPower59 » Tue May 28, 2013 9:17 pm
In my opinion, a quality gauge would be the first thing I would buy. High temps kill transmissions.
Postby 93 W350 LE » Wed May 29, 2013 5:45 pm
I am planning a fluid and filter alobg with band adjustment. Also want to add another cooler and a new temp gauge.
With 4:10's and the stock H1C, how much will a tighter convertor help or hurt? I want to be able to haul my 14k 5th wheel at hiway speed or close to it.
Thanks.
Eric
93 W350 LE Club cab dually automatic, Banks Power Pack w/ exhaust, Banks tach and pyrometer, Isspro boost gauge, GearVendors O.D., BD exhaust brake, Kelderman Compuride and front bags. My Dad was the 2nd owner.
So far; rotated fuel pin, bottomed star,1/2 turn on smoke screw.
Daily driver and occasional 14k lb 5th wheel hauler.
Thank a veteran for your freedoms!
93 W350 LE
Postby peobryant » Fri May 31, 2013 3:42 am
A better torque converter is one of the best things you can do to improve these transmissions. The stock unit leaves a lot to be desired, to say the least, but we have quite a few options to improve them. I would contact Dave Goerend about a converter for your truck, let him know what it is used for and what you're looking for and he can determine the best one for you.
Postby 93 W350 LE » Fri May 31, 2013 8:00 am
A converter is definately on the Christmas list. Even if it's the same stall just a better built converter.
Eric
93 W350 LE
Postby RCCUMMINS89 » Fri May 31, 2013 10:30 am
Most of he aftermarkets stay close to the same stall....... the fact that is a better converter is all the notice in the world.
Postby tampabayBill » Mon Jun 03, 2013 8:17 am
Before dropping in a 47rh, I towed a 14k 5th wheel with my rig. Had a 518 with suncoast convertor, transgo tfod kit stock coolers and a magtec double deep pan. I towed from Tampa to Beaumont, Tx. and never saw above 180 on the tranny temps. Might want to think about upgrading the radiator.
Twins coming soon!
tampabayBill
Postby 93 W350 LE » Mon Jun 03, 2013 3:04 pm
What are some recomendations for aftermarket trans coolers for my set up?
Thanks.
Eric
93 W350 LE
Postby tampabayBill » Wed Jun 05, 2013 6:40 am
Do you have the stock under bed cooler with fan ? If so should be fine, if not check B&D or several others . Google trans coolers.
Twins coming soon!
tampabayBill
Postby ellis93 » Wed Jun 05, 2013 8:07 am
93 W350 LE wrote:What are some recomendations for aftermarket trans coolers for my set up?
Thanks.
Eric
You want a plate style cooler.. not a tube cooler.
Postby 93 W350 LE » Tue Jun 11, 2013 9:46 am
Thanks.
Eric
Do tell the difference, please.
Eric
93 W350 LE
Postby 93 W350 LE » Tue Jun 11, 2013 9:49 am
tampabayBill wrote:Do you have the stock under bed cooler with fan ? If so should be fine, if not check B&D or several others . Google trans coolers.
No factory cooler under the bed, that I've seen. Will crawl under and give a good look. I hread they were usually near the fuel tank.
Eric
93 W350 LE
Postby 93 W350 LE » Sun Jun 16, 2013 12:55 pm
So I found a Hayden plate style cooler, recommended for rv's and vehicles towing more than 10k, and a Hayden fan for just over $100, are they quality or are their any better recommendations?
Thanks,
Eric
93 W350 LE
Postby ellis93 » Sun Jun 16, 2013 1:25 pm
That's good stuff,all I've really ran. Never had a problem with any of their stuff
