What fluid in your auto's?
Postby 93 W350 LE » Fri May 31, 2013 7:15 pm
What fluid are you guys running in your auto trans? My dipstick says DexronII but that is not available. Have been using ATF+4,is this necessary? What is best for towing and longevity?
Thanks.
Eric
93 W350 LE Club cab dually automatic, Banks Power Pack w/ exhaust, Banks tach and pyrometer, Isspro boost gauge, GearVendors O.D., BD exhaust brake, Kelderman Compuride and front bags. My Dad was the 2nd owner.
So far; rotated fuel pin, bottomed star,1/2 turn on smoke screw.
Daily driver and occasional 14k lb 5th wheel hauler.
Thank a veteran for your freedoms!
93 W350 LE
Re: What fluid in your auto's?
Postby dunes450r » Fri May 31, 2013 7:18 pm
i used atf4, plus a bottle of luck auto trans when i had an auto
dunes450r
Postby Tacoclaw » Fri May 31, 2013 7:19 pm
Correct me if I'm wrong, but doesn't each higher number of Dextron supersede the last?
As in you could run Dex 2-5 in our trucks but not Dex1?
Also, like dunes said, I thought Mopars used +4? Don't Fords run the Dex/Merc?
Postby BC847 » Fri May 31, 2013 8:08 pm
Some generic tractor hydraulic fluid (I'll need to look) with a little ATF4 so I can see it on the dip-stick.
Postby dazedandconfused » Sat Jun 01, 2013 5:11 am
I'm running half JD hydraulic oil and some cheap at. When I flushed mine when I got it fluid was brown and stunk. After 10k miles its still clear with a little red tint but I can still could use a rebuild.
Postby 93 W350 LE » Sat Jun 01, 2013 5:38 am
Tacoclaw wrote:Correct me if I'm wrong, but doesn't each higher number of Dextron supersede the last?
Yes the higher Dex supersedes, all my old Mopar ran DEXIII and my dipstick says DexII, the newer stuff runs +4( my 97 Dakota I sold), and Fords used to run typeF, if I remember correctly.
I've been reading some of you are just running hydrolic fluid, and the higher viscosity is supposed to help "tighten" it up a little bit. Any thing bad associated with this?
Thanks.
Eric
93 W350 LE
Postby cmann250 » Sat Jun 01, 2013 6:23 am
93 W350 LE wrote:I've been reading some of you are just running hydrolic fluid, and the higher viscosity is supposed to help "tighten" it up a little bit. Any thing bad associated with this?
I haven't found any ill effects over the last 25-30k miles. You'll really notice a difference at first if your transmission has some miles on it.
Postby 93 W350 LE » Sat Jun 01, 2013 10:34 am
Just turned 180k, so planning some maintenance. Fluid,filter,bands,linkage,etc...
Eric
93 W350 LE
Postby dazedandconfused » Sat Jun 01, 2013 10:42 am
I'd do 50/50 mix of hydraulic oil and ATF.
Postby Sutter1stgen » Fri Jun 07, 2013 7:41 pm
I run napa brand ATF+4. I don't run anything special. That's cool that you guys run tractor trans fluid. Do you thing id be okay running some JD hyguard??
Eric
Sutter1stgen
