Getrag shifter
Getrag shifter
Postby banjobob » Mon Jun 17, 2013 10:56 am
Hello i recently picked up a 92 ext. cab 4x4 with getrag with 450,000 kms and no speedometer. truck was stuck in 4th so i removed top cover and a roll pin came out but was still hanging on by a bit so all was well but when i put the top cover on i could not move the stick from side to side. if the snap ring is not all the way in it will work but i would feel more comefortable if i could put the snap ring in till it snaps. and ideas?
banjobob
Re: Getrag shifter
Postby PToombs » Tue Jun 18, 2013 5:18 pm
Pull the shifter back out and make sure the slots in the rails are all in line. It may be stuck in 2 gears or the shifter may be in 1 and the trans in another.
