which hydraulic fluid
Postby ellis93 » Mon Jul 15, 2013 4:59 am
Gonna put some in the 47rh trans for the 82,and I'm needing to know what different kinds folks have ran. I already know that the Deere stuff will be top of the list because of the fact that Deere stuff has some kind of magical properties to it,what I don't know is if something like 303 has proven to be just as affective in the trans.
Re: which hydraulic fluid
Postby rockbuggy4x4 » Mon Jul 15, 2013 6:57 am
I'm interested as well. Might put some in my 727 to help it when I go to pick up my crew cab. I've read some threads that people run a 50/50 mix between hydraulic fluid and trans fluid.
Jimmy
--> '95 jimmy not so stock
rockbuggy4x4
Postby ellis93 » Mon Jul 15, 2013 8:03 am
That's what I'm figuring to do.....mix it. Only I want a fluid that is readily available to me.....something I don't have to go out of my way for :lol: and don't get raped when buying it either
Postby rockbuggy4x4 » Mon Jul 15, 2013 8:23 am
I believe theres different viscosities but I'm not 100% sure.
Jimmy
rockbuggy4x4
Postby Mark Nixon » Mon Jul 15, 2013 1:02 pm
John Deere makes "quality" stuff? :shock:
Who knew? :P
Postby ellis93 » Mon Jul 15, 2013 1:16 pm
Mark Nixon wrote:John Deere makes "quality" stuff? :shock:
Who knew? :P
Yeah......if you buy into the hype :roll: Half the price of a 5 gallon bucket of their "quality" fluids is made of hype,the rest is hopes,dreams,pixie dust and fairy farts :lol:
Postby Mark Nixon » Mon Jul 15, 2013 1:25 pm
ellis93 wrote:...fairy farts :lol:
You've heard/smelled "fairy farts"? :shock:
Better yet, you've seen a fairy? :P
The wonders we see in this old world. 8)
Postby ellis93 » Mon Jul 15, 2013 1:30 pm
I'm quite sure Elton John passes gas every now an again :lol:
Postby Mark Nixon » Mon Jul 15, 2013 1:35 pm
ellis93 wrote:I'm quite sure Elton John passes gas every now an again :lol:
Not a fart grader, so I wouldn't know, myself. :roll:
Anyway, expensive (JD?) hydraulic fluid is the topic. :lol:
Postby cmann250 » Mon Jul 15, 2013 4:20 pm
http://www.countrymark.com/countrymark/ ... _Fluid.pdf
Here's what I got going on. For the longest time I thought I had Deere hydraulic fluid because it was green, it came from a Deere barrel, and the local Deere dealer is family to my boss. Turns out that I have Co-Op hydraulic fluid. Oh well it works and the price was still right ;)
Postby dazedandconfused » Mon Jul 15, 2013 5:58 pm
I've heard guys have good luck out of the Orieleys brand tractor hydro oil. I can first starting yo slip in mine taking off and second every now and then. I'm running the Deere oil and its done alright but I can smell a burnt smell in my fluid now. I'm getting ready to order my kit for my 47rh and don't know if I'll do tractor fluid again.
Postby ellis93 » Mon Jul 15, 2013 7:15 pm
Reckon you were riding on borrowed time any way or do you think it helped the trans along Andy
Postby BC847 » Mon Jul 15, 2013 7:57 pm
I've been running some cheap, by the 5-gallon drum generic stuff with a little ATF4 to color it a little for a while now. No issues that I'm aware of.
When I first switched to it, I did notice a little better pull in the seat with it being a little thickerer and all.
Postby ellis93 » Mon Jul 15, 2013 8:04 pm
BC847 wrote:I've been running some cheap, by the 5-gallon drum generic stuff with a little ATF4 to color it a little for a while now. No issues that I'm aware of.
BC thanks for the info :thumright:
If I could.... :D I'd like to ask what kind of filter your sporting in the pan. Stock old school,plastic cased newer,or screen?
Postby Mark Nixon » Mon Jul 15, 2013 8:10 pm
I'm running generic hydro oil in the '96 and it seems to take longer to shift with it and sometimes I have to actually let off and ease into it again before it'll make the shift.
It likely has to do with viscosity.
Then again, I have been less than impressed with it, as an automatic, than I usually am with autos.
