by Sutter1stgen » Fri Oct 04, 2013 6:33 am
My father has a 99' with 4.10. If he didn't use od he would get nowhere quick. No matter how heavy the load, he's utilizing od when the truck will allow it. Towing his 16' edgewater fishing/ski boat up to the lake he never has to pull over to allow for passing, and his trans never hunts for the right gear.
Take this with a grain of salt, but I've always been under the impression that anything over 1600 rpm and your trans is making sufficient line pressure. I personally won't shift into od until about 65 mph. I have 3.07 and a A518. I'm at about 82 mph at 2k rpm.
As long as you feel comfortable with your line pressure, load applied, and road conditions (hills/flats), I see know reason why you couldn't pull in od at a safe towing speed.
Eric
