skilletky wrote:Diesel, if you use the POT siwtch method, it will kick into OD automaticly, and you can adjsut at what speed it kicks into auto. if you wanted to, you could wire in a 3 position toggle switch, on/off/on. have one "ON" position for the POT switch, "OFF" would be no OD, and the other "ON" position would be to put it into OD when it is switched on.
dazedandconfused wrote:Mine won't kick down I have to cancel out od.
