93 4x4 auto 727 ?
93 4x4 auto 727 ?
Postby Jwindsor » Wed Oct 09, 2013 2:24 pm
Hey guys.. pretty new to these trucks and had a question.
Are any of the 727's out of gas d250's or ram chargers compatible in my 93 diesel ?
or is it specific to the diesel only 89-93 ?
thanks alot!
Jwindsor
Re: 93 4x4 auto 727 ?
Postby BC847 » Wed Oct 09, 2013 3:31 pm
WELCOME to our forums. :)
Your '93 W250 has an A518 (AKA: 46RH) transmission. It amounts to a 727 with an overdrive section added. In fact, many of the parts from a 727 are interchangeable with the later Dodge 46RH, 47RH & RE, as well as the 48RE transmissions.
Typically those transmissions for the Diesels (and V10) trucks include heavier planetary gear-sets, etc as compared to the gas versions. Further, the diesel versions include a different governor assembly tailored to the diesel's lower engine RPM ( a gas transmission behind a diesel will result in the diesel having to rev excessively too high before the trans gets around to shifting gears.
Postby PToombs » Wed Oct 09, 2013 5:03 pm
Welcome! The torque converter is set up differently to compensate for the diesels lower rpms also.
