overdrive stuck
overdrive stuck
Postby Knoberman » Sun Oct 20, 2013 6:43 pm
Truck was fine this morning got in it after work and as soon as it hits third it goes into overdrive. Its set up on a switch, everything seems ok with the switch finally unplugged the solenoid and its still in overdrive.
So I assume the solenoid crapped on me?
92 Cummins& a 518. installed in a 86 cclb f350 4x4
Knoberman
Re: overdrive stuck
Postby ellis93 » Sun Oct 20, 2013 6:53 pm
I would assume as much too.
Re: overdrive stuck
Postby Knoberman » Thu Nov 28, 2013 7:19 am
Smoked the tranny now has 47rh.
Knoberman
