Remps wrote:47RH isn't electronic. 47RE is.
Sutter1stgen wrote:Which transmission does your 91' have. 3 or 4 speed? I know my 91' came with the a727 3 speed. I was happy with it for 4 years. But when it finally blew the 3rd time I had a A518 ready to go in for the next round. I actually built the trans myself, they are pretty straight forward. BC847 did a extensive trial and error rebuild if you do a search on it. I learned a lot from his thread, and from PMing him on his thoughts.
If you can live without o/d then build the trans you have with a valvebody and converter. That is always a start. Now is your truck 4x4 or 2wd? Because if your going to be doing any 4x4 launches, a steel front planetary set is a good piece of insurance. After that billet shafts are going to be needed quick.
Let us know a little more about your truck and its intended plans for this 400hp goal.
Sutter1stgen wrote:Build the budget friendly trans it already has. If o/d ever crapped out on you you could throw it on a toggle and still have o/d. A518 trans are alot stronger than most people think. If it isn't going to be a tow pig, I wouldn't spend the extra money on another transmission, especially one that has a converter that cost a minimum of twice the cost.
Sutter1stgen wrote:Oh and another thing to think about. Firstgen frames are designed to bend and break in certain spots apon collision!! If you do decide to use your truck as a 10k battering ram,,,,,,, I'd strongly advise plating and gusseting in the key areas.
Driving my boss's truck thus morning also reminded me of another point, gearing. 3.55s are cool and all, but with 36-14.50s they can be a bit of a henderence. Add a heavy truck loaded with gear and add ons and you ply compound it. If you have o/d, and plan on 35" or taller, I'd go with 4.10s. They are about as low as I'd go until you get to the 40"+ tire size.
Users browsing this forum: No registered users and 87 guests
