Automatic stays in 2nd.
Postby fxr3 » Wed Nov 13, 2013 10:50 pm
My 93 w250 has 111k. 5k ago I had tranny "serviced" after a cooler hose blew off(tranny fluid is not good windshield fluid). Ive always maintained truck, so I think tranny is good, but out of adjustment. Ive read here how to adjust shifting, but I'm getting old and rather someone else do it.
It will shift from 2nd to 3rd by encouraging it- full throttle then back off, but tends to want to go back to 2nd with any aggressive throttle input.
Do most tranny shops know how to make correct adjustments? Thanks in advance, Barry
fxr3
Re: Automatic stays in 2nd.
Postby skilletky » Thu Nov 14, 2013 8:49 am
check your line pressure. easy check to let you know what is going on. i cant remember what port it is to hook the guage to.
skilletky
Postby PToombs » Thu Nov 14, 2013 4:10 pm
Sounds like the TV cable is stuck in the accelerated position. Just look under the hood at the throttle linkage and see if the cable is all the way forward or pushed back.
Postby fxr3 » Sun Dec 15, 2013 10:39 pm
I would say the cable was stuck. I douched them with cleaner, lubed them with WD40. Drove a 1000miles, and she shifted perfectly. Thanks, Barry
fxr3
