Np 205 fluid
Np 205 fluid
Postby 92cummins89 » Thu Nov 21, 2013 9:40 pm
Wondering wat kinda fluid y'all guys running in ur np205 weight and brand thanks
92cummins89
Re: Np 205 fluid
Postby RCCUMMINS89 » Thu Nov 21, 2013 10:05 pm
I normally run regular old gear oil. 75w-90 or something like that, I forget...
But, now I run the nv4500 stuff...just in case they swap fluid, my nv won't be getting regular gear oil.
Re: Np 205 fluid
Postby 92cummins89 » Thu Nov 21, 2013 10:11 pm
I got an nv goin I'm my truck, gonna find out wat he put in my tranny an go with tht
There anything I should know when puttin the tcase an tranny together
92cummins89
Re: Np 205 fluid
Postby RCCUMMINS89 » Thu Nov 21, 2013 10:15 pm
The nv4500 requires a special synthetic fluid, I forget what it's called...but it's about 20 bucks a quart at the dealership.
Re: Np 205 fluid
Postby 92cummins89 » Thu Nov 21, 2013 10:49 pm
Dammit didn't know tht. How many quarts does an nv 4500 hold
92cummins89
Re: Np 205 fluid
Postby RCCUMMINS89 » Fri Nov 22, 2013 7:56 am
Uh...... 4? I bought like 7 or 8 quarts for both and had a lot of left over.
Re: Np 205 fluid
Postby dunes450r » Sun Nov 24, 2013 9:05 pm
i've just ran 10/30 synthetic in my 205
dunes450r
Re: Np 205 fluid
Postby CumminsPower59 » Mon Nov 25, 2013 8:13 am
NV4500's take four or so...I was told to overfill it just like the Getrags, I've been running five quarts of Redline in mine since this spring, seems to do well. I have just generic 80w90 in the 205 as of now, but when I do change the lube in the NV, I will do what RC is doing, using the same lube for both the NV and the 205. I got twelve, one quart jugs at work of the GM NV stuff, they haven't used it in years and were going to dump it...I'm gonna run it for a while when I cange the fluids next spring.
Re: Np 205 fluid
Postby 1STGENFARMBOY » Mon Nov 25, 2013 8:22 am
I think the NV has a tag on the side that says (syntorque) or something like that.
and for some reason my brain thinks castrol makes it.
