new trans now no neutral or reverse or park
Postby Jl0696 » Wed Nov 27, 2013 12:39 pm
got a rebuilt trans from a 2wd put my 4wd overdrive housing on it installed it and now i only have park and all drive gears the shift lever feels weird between park and drive even with the linkage disconnected. i had a hard time getting the rod to slide into the overdrive housing could this be the problem and i need to pull the od housing back off to fix this? or is there another possible solution?
Jl0696
Re: new trans now no neutral or reverse or park
Postby Jl0696 » Wed Nov 27, 2013 3:57 pm
ok been messing with the shift lever on the side of the trans and originally there was only 4 detents now i can feel 5 detents but ive lost park and moving the lever between the 5 detents while the truck is running all give me forward movement of the tires while the rear is jacked up
Jl0696
Postby PToombs » Wed Nov 27, 2013 6:07 pm
Sounds like the shift lever in the trans is not in the detent in the shift spool. The spool is stuck in one of the forward gears, probably 1st, and won't come back out because the lever is not in the slot.
Postby Jl0696 » Wed Nov 27, 2013 6:16 pm
but i had park before i started playing with the lever. sounds like i will be pulling the pan tomorrow regardless its a place to start at least
Jl0696
Postby ellis93 » Wed Nov 27, 2013 6:24 pm
Postby Tacoclaw » Wed Nov 27, 2013 7:16 pm
Can we make it a sticky that anyone with an auto shifting questions should have to put "twatwaffles" in the search first thing? :lol:
Postby ellis93 » Wed Nov 27, 2013 7:33 pm
Tacoclaw wrote:Can we make it a sticky that anyone with an auto shifting questions should have to put "twatwaffles" in the search first thing? :lol:
That's the only thing I could remember about that tread :lol:
Postby Jl0696 » Thu Nov 28, 2013 11:09 am
that is the problem the lever is not engaging the spool valve. now how do I fix it. and the nss and the plastic piece it engages seams to be different. I swapped the nss but it doesnt engage the plastic piece properly
Itook pictures just dont know how to post them from my phone.
Jl0696
Postby dazedandconfused » Thu Nov 28, 2013 11:55 am
If you have a smart phone the link in my SIG will tell you how to post pics.
Postby Jl0696 » Thu Nov 28, 2013 12:33 pm
Jl0696
Postby Jl0696 » Thu Nov 28, 2013 3:51 pm
thats the new plastic piece heres the old one looks like the new one is broken what is the part called so i can order a new one
here's the 2 nss old on the right new on the left
and I got internal lever into the right position on the spool valve but it slips back out when I move it through the gears can I just bend it down ?
Jl0696
Postby PToombs » Thu Nov 28, 2013 4:09 pm
Both NSS are the same and look OK. The rooster comb plastic thing is broken on the pic labeled "new one", so the neutral start and reverse lights won't work right. The plastic insulates it, for reverse lights it pushes in and connects the switch, for neutral it grounds that pin on the NSS to the lever. You are going to have to drop the VB and replace the shifter shaft with the rooster comb. And yes, you can bend the lever down some if you need to.
Postby Jl0696 » Thu Nov 28, 2013 4:38 pm
you cant see in the pics but the electric connections are different so i had to swap them. i guess ill pull the manual lever out of the old trans to get the truck on the road. thanks for all the help and quick responses.
Jl0696
