i just put on a stock replacement of my master/slave cylinder assembly from partsgeek.com. but when i connect the master cylinder pushrod to the clutch pedal the eye on the push rod is too big for nob on the clutch pedal so it could pop off anytime. any ideas how to solve this. also the clutch pedal naturally drops below the break pedal i heard this isnt right but it used to be an auto so idk if that makes a difference
any info is greatly appreciated thanks
