Torque Converters.... which one.
Postby 2muchtq » Sun Nov 18, 2007 9:47 pm
I am getting the parts together to follow BC's thread on reBUILDING my tranny. I have a buildable core that I am going to take my time on... so doing it right wont step aside due to me needing my truck running.
I have a quesiton on converters. I can get a Dunrite for a deal.
I have NO experience with these converters for the first gen. I know the Dunrite builds that Rip does holds PLENTY of power... I am just curious if anyone knows how 'tight' these converters are.
I have owned an 89% DTT and it was plenty loose to spool at the line. But this was a lockup converter (95RH tranny)
Unk has a 91% in his full DTT and I LOVE the way it works... just do not want to spend the coin on a 91DTT converter.
So... long winded post aside. Anyone have experience with different converters?
Anyone running a converter that they would reccomend for 400+ HP?
Thanks everyone
Mark
2muchtq
Postby JD730 » Mon Nov 19, 2007 5:18 am
I have a Goerend 3 disc. Thats the only one I've ever run so I don't have anything to compare to.
If you want to put power down I would look for a lockup style core to rebuild. No matter how tight you make the fluid coupling its still not 100%.
Mike
The "Rattle Box"
JD730
Postby BC847 » Wed Nov 21, 2007 12:27 am
I think you'll find most if not all the major converter re-builders have stopped marketing the commonly named 89% and 91%. Reason being, too many problems with customers expecting "Better" performance. Most of which have no idea of how what goes into the converter (HP/torque/RPM) dictates what comes out. Certainly with the rotating and stationary components in closer relation, more apparent power is transmitted.
As such, most now market a single modified version. When asked how tight in the common %, most will balk rightfully thinking "Aw Jeez! Not again!!"
Still though most builders can custom set one to your liking allowing time for the work. Else, it's usually an off-the-shelf swap for your core.
I went with SunCoast hoping there's something to the reliability of the brand. Further, that they offer has the billet backplate (that which mates to the flex-plate). The idea being to help further reduce flexing.
I think DunRight is relatively new in terms of a reputable/established converter vendor. I'm seeing more and more references to them.
Considering it's all the same converter cores that they all work with, it's a matter of how well the machine work is done in tightening them up. General "Good workmanship" practices being foremost.
We'll see.
Hope this helps. ;)
(Work with me, I'm on muscle relaxers & pain meds due to a recent back injury). Image
Postby JD730 » Wed Nov 21, 2007 4:59 am
BC847 wrote:I think DunRight is relatively new in terms of a reputable/established converter vendor. I'm seeing more and more references to them.
Dave,
Dunrite has been in the trans/converter business for years. For reasons that are unknown to me it seems they've been sitting on the back burner for years.
Mike
The "Rattle Box"
JD730
