Dual disc in a Getrag ? opinions
Postby jmd4993 » Fri Dec 13, 2013 4:36 pm
Dual disc in a Getrag ? opinons
i did a getrag swap on my 92 w250 and i called valair and told them that i want the capability of towing and something that will last and im a def beginner at trannys so they recommended the dual disc. so i got and we installed it and 3rd girl is grinding from the first time i tested it out. they guy i bought the tranny from said it was perfectly fine and he would like it back if i get a different one.
he thinks that the clutch is disengaging far enough because i dont have the heavy duty clutch hydraulics. but everyone tells me its a syncro and common sense says its a syncro. which is fine, its the luck of the draw.
i called valair about an exchange. no can do. they also said that the rotating mass is only 10lbs more that a single disc and it wouldnt effect the syncros as dramatically as people have said. they said it was a very stock and street friendly clutch with capability.
so im buying a new rebuilt tranny. now the big question is, do i keep the dual disc, get a performance single disc, or use the used stock clutch?
i would greatly appreciate any first hand experience with a dual disc and what happened and the longevity of a tranny mainly the getrag with one in it.
any info is greatly appreciated thanks a lot guys
__________________
jmd4993
Re: Dual disc in a Getrag ? opinions
Postby 93flatbed » Sat Dec 14, 2013 12:50 pm
I do not have a getrag any more. I do have a duel disk. It didn't effect my transmission at all. The shipping lable said 89 lbs when FedEx dropped it off at the gate.
I doubt that information helped you at all. Only thing I can think of, as you mentioned is its not fully disengaging and an already worn synco is showing up more now.
93flatbed
Postby RCCUMMINS89 » Sat Dec 14, 2013 10:02 pm
Check your pedal bushings/throw. VERY common problem with our old trucks. A single disc doesn't have to be moved as far to fully disengage.
Postby BILTIT » Mon Dec 16, 2013 1:01 pm
I didnt have any problems with my dual disc. I would double check linkages/bushings/etc. as has been said above.
Did you install the discs/spacer the proper orentiation as they were marked?
Derek B.
BILTIT
Postby jmd4993 » Mon Dec 16, 2013 9:22 pm
where do you check the pedal bushings throw? i just installed a new stock replacement master and slave cylinder. i was told by many people to get the Heavy duty clutch hydraulics but valair said i didnt need it. thats for the info guys
jmd4993
