Help! 727 Tailshaft Housing Removal Issues
Postby Mckinney » Fri Dec 20, 2013 1:43 pm
I have purchased a used gear vendors unit and I have all of the parts off and ready to go except I am unable to remove the GV tailshaft housing that connects to the GV unit itself. I've contacted GV and their instructions guided me to messing with the parking pawl but I've tried everything with no luck. This is the third time I have made the 2 hour drive out to try and remove this section. I really don't want to do it again. Anyone have any ideas or tips on how to remove this tail shaft housing?
I have it disconnected from the trans and I can pull it away from the trans about 1/4" at the most. It will turn freely unless in park but it feel like it snags on something and won't slide off.
Mckinney
Re: Help! 727 Tailshaft Housing Removal Issues
Postby draginmopars » Fri Dec 20, 2013 1:55 pm
there is a snap ring under a plate with to Phillips head bolts holding the plate
http://www.justanswer.com/chrysler/25zp5-727-trans.html
Howard
Ha-Ha Racin
Havin Fun 101
draginmopars
Postby Mckinney » Fri Dec 20, 2013 2:20 pm
That's what I thought too but on the Gear Vendors tail shaft housing that plate and slot are not there. It's just flat metal with mounting holes for the crossmember. I'm at a loss right now :@:
Mckinney
Postby draginmopars » Fri Dec 20, 2013 3:04 pm
i mis read the post
your trying to get the GV apart
I looked at them during Drag week
looks to be only
8 bolts holding it together,
depending on the gasket they use
it may have glued itself together
Howard
Ha-Ha Racin
Havin Fun 101
draginmopars
Postby Mckinney » Fri Dec 20, 2013 5:41 pm
I finally figured it out with the help of a more knowledgeable tech at GV. There is what they call a coupling bolt that holds everything in place from the opposite end of the transmission. It was a bear to break loose especially while under the truck but I finally got it off. Thank you for your help anyway! I just scored a complete GV unit, driveshaft, and rear axle for $500! Whoooo!
Mckinney
