full manul vb in a 727 questions
Postby Joecochrane » Thu Jan 16, 2014 10:37 am
I plan on converting my truck to a full manual vb. Question is will I still have to run a tv cable. Motor and trans is in a f350 with my home made linkage and I'm having trouble syncing the throttle linkage with the tv linkage.
The driver 02 2500 ho 6 speed 2wd lil lift 35s edge cts hot some injectors and a fass
The toy 87 f350 39.5 tires 180 bus motor 727 trans maxed pump ground pin bumped timing 366 spring hx35 and a lot more in the works.
Joecochrane
Re: full manul vb in a 727 questions
Postby DMan1198 » Thu Jan 16, 2014 10:38 pm
You'll need a cable from the trans to the shifter yes (I think that's a tv cable). If your truck is already an auto with that thing hanging off the top of the pump then with the manual vb you can remove that
Postby dazedandconfused » Fri Jan 17, 2014 3:47 am
I believe you still need the TV cable unless its a constant pressure VB.
Postby Joecochrane » Fri Jan 17, 2014 8:20 am
Dang I will have to look into it a lil more.
Joecochrane
Postby dazedandconfused » Fri Jan 17, 2014 9:04 am
Call these guys And ask them.
http://www.aandatrans.com/
Postby Joecochrane » Fri Jan 17, 2014 10:48 am
Thanks not quite ready to tear into the trams yet. I've still got a few more parts left to squeeze a ill more power out of the engine.
Joecochrane
Postby dazedandconfused » Fri Jan 17, 2014 11:13 am
They should be able to Awnser any questions you have.
Postby Joecochrane » Fri Jan 17, 2014 12:48 pm
Checked out there web site they do look like they no there way around a 727. Thanks for the link.
Joecochrane
Postby Sutter1stgen » Sat Jan 18, 2014 9:40 pm
Some of the best mopar Trans guys. Even the sales tech in over there knows his stuff. He started rattling specs off for a turbo 350 to me when I called them once.
Eric
Sutter1stgen
