gasser 727 behind a cummins?
Postby sloppy2nds000 » Sat Jan 25, 2014 9:47 pm
can a 727 from a motor home be a substitute tranny? if so, is there anything that has to be swapped to make it work in stock trim? and if not can they be built up to work behind our 6bt's?
i googled it and didnt find a solid answer.
91 w250 a518 regular cab plow truck, bone stock, just over 100k, 1 ton front springs and air bags in the rear
94.5 f350 crew cab long bed powerstroke, 100hp beans injectors, solid state chip with 6 pos switch, adrenaline HPOP, about to turn 300k, summer work truck.
1970 bmw 2002, inka orange
1987 vw golf gti, 2.0l conversion
1994 bmw 525i
sloppy2nds000
Re: gasser 727 behind a cummins?
Postby Tacoclaw » Sun Jan 26, 2014 5:34 am
The diesel 727 has it's own, specific bell housing pattern. No other cases will work behind the diesel.
Postby sloppy2nds000 » Sun Jan 26, 2014 5:59 am
well thats a bummer. i guess it was wishful thinking.
1994 bmw 525i
sloppy2nds000
Postby Tacoclaw » Sun Jan 26, 2014 6:07 am
Yup, sorry, man. :(
I think the internals are mostly the same, you may be able to pirate some parts out of it if it'll help you.
Postby trucker_dad » Sun Mar 16, 2014 1:49 pm
I have a working 727 and everything from a 90 cummins
trucker_dad
Postby BC847 » Sun Mar 16, 2014 2:43 pm
The Cummins version of the 727 (and those forward) have beefed-up planetary gear-sets. Those in the 3-speed section have four spider-gears, and that in the over-drive section has five. The heavy-duty planetary gear-sets are unique to the diesel units. The clutch-pacs have increased clutch/steel counts. The governor weights of the diesel unit are made of brass. The heavier weight allows for the lower shift-points common to the diesel. They are not interchangeable with the gasser version.
Postby cumminsfarmer » Tue Mar 18, 2014 4:21 pm
If you feel like driving to se pa I have a diesel 727 from a 89 4x4 just the trans . also have starter flywheel and engine adapter plate.
89 w350 srw 92,000 orig miles. built 47rh swap, he351cw, 5x16's, sumped tank, 1/2" lines custom fuel system. Pump maxxed, Denny t stage 2 fuel pin, 355gsk, powerstroke ic.
Sold-91.5 4x4 auto intercooled . Tweaked pump,Denny t stage 2 fuel pin, 2nd gen pump kit, pot mod, 4 inch turbo back, he351ve custom controller
cumminsfarmer
