How to modify the valvebody to lockup in 1st.
Postby DodgeFreak » Fri Jan 31, 2014 8:16 pm
any ideas??? I'm thinking about doing this to my cousins 98 12v cummins. I'm going to put a manual shift kit in it. I've glanced through the flow chart alittle but my main computer crashed a while ago and it has the colored ondemand version I had and the college changed the password on me last year, (I haven't been in college since may 08) lol.
Re: How to modify the valvebody to lockup in 1st.
Postby txs » Mon Feb 03, 2014 4:59 pm
Wouldn't be simple, the supply for the lockup control circuit comes off the 2-3 shift valve, that's why 518, 47rh and 47re only lockup in direct and overdrive. The 48 re will lockup in the lower gears, and the vb parts will retrofit to 47s according to one of the fliers I was reading in a tranny shop, not sure about 518s.
txs
Postby DodgeFreak » Mon Feb 03, 2014 5:11 pm
so you'd be better off running a 48re valvebody\parts? if you can.
