most miles on transmission without a rebuild
Postby lineman » Sat Feb 01, 2014 4:09 pm
Im at 240,000 on od. I think its the original A518. Bands were very loose.
93 w250 A518 4x4 white new to me
lineman
Re: most miles on transmission without a rebuild
Postby cmann250 » Sat Feb 01, 2014 5:01 pm
271k. The transmission is still decent, but the torque converter is toast.
I aim to fix that here shortly.
Postby matthewh » Sat Feb 01, 2014 10:40 pm
Dads 93 D250 was pushing towards 299k, orig trans, never rebuilt, just regular service and adjustments. Had the Super Duty cooler too. Not a ton of towing, but summer was filled with hay season for many years
matthewh
Postby motorhead540 » Sat Feb 08, 2014 11:43 pm
my 93 CCLE 4X4 has really close to 300,000 and still works the converter is very free and needs to be replaced truck has been semi retired until recently when I purchased a 5210 deere 4x4 and now I need to do some work and or upgrades to be comfortable hauling the trailer and tractor around . trying to figure out what trans it has for sure first then what should be done to make it live another 2-300,000 as I really cannoy afford to buy a new truck but why should I the engine runs great and doesn't smoke yet
motorhead540
Postby meby » Sun Feb 09, 2014 6:40 am
Dad has 430,000 on his getrag thats never been rebuilt.
-1991 D-250 bone stock
-1997 Civic Hatchback
-Case 530 CK
-Speedex Walking Tractor.
-BCS Walking Tractor
www.ebyfarmsllc.com
meby
Postby PToombs » Sun Feb 09, 2014 5:14 pm
Matt, that's scary. I'll bet it's due to have bearings put in. Mine had 229k when the counter shaft bearings went out.
Postby tim curran » Sun Feb 16, 2014 6:58 pm
This trucks must be flatlander trucks, cause I have had to 4 torque converters and three trannys in the last 300k miles. A course sled pulling and Dyno runs and towing 14000 lbs didn't help.
1993 w250, 3200 RPM springs, maxed fuel screw, industrial inj. Fuel pin, Dynamite diesel 75 horse inj., ind inj stage 2 pump, 60 lbs valve springs, ARP head studs, Banks ram air intake. 4 inch diamond eye exhaust,16cm turbo housing, 60 mm comp. Housing, BD tourqe converter, billet flex plate, Banks gauges, 212hp 608 tourque, old smokey and worn out.
tim curran
Postby matthewh » Mon Feb 17, 2014 12:25 am
Nope, Michigan is quite hilly, at least up north it is. We used dads truck for everything, farming/livestock all year long, hay when ready to cut/bale, firewood come fall, general truck duty. Preventative maintenance helps em last,
matthewh
Postby RCCUMMINS89 » Mon Feb 17, 2014 8:19 am
If we are bringing up manauls, my dad's truck is well over 300,000 and probably getting close to 400k with the original clutch and transmission.
Postby cmann250 » Mon Feb 17, 2014 8:37 am
The owner's definition of "broke/needs a rebuild" and driving style have a huge impact on how long they last.
I maintain that you can't kill a LoadFlight with a stock converter. I've been trying for going on 3 years.
Postby cougar » Mon Feb 17, 2014 10:50 am
91: 290K on a Getrag. Really only needed syncros, but got a full rebuild. Destroyed a month later in a wreck.
92: Unknown. It had 145K when I bought the truck and 165K when the A518 was overhauled. Found out at that time the transmission had been replaced with an unknown mileage junk yard one that was in sad, sad shape.
01 2500 "the work truck".
cougar
Postby galakinokis » Sat Apr 12, 2014 6:51 pm
This is getting close to the "my truck gets 29mpg towing"
galakinokis
Postby meby » Sun Apr 13, 2014 6:48 am
PToombs wrote:Matt, that's scary. I'll bet it's due to have bearings put in. Mine had 229k when the counter shaft bearings went out.
My dad drives like a grandpa and when he tows a trailer (which isn't real often), he always tows under the gwr and slows down even more. Suffice to say he uses it real nice. :lol: He's the only guy I know that has gotten 28 mpg out of a tank in a 4x4 3/4 ton. Heck the best I got out of my last 2wd was 26 mpg. I'm still trying to figure that one out. :oops:
-Case 530 CK
www.ebyfarmsllc.com
meby
Postby rockmike » Mon Apr 14, 2014 2:14 pm
390,000 on mine...original transmission.
93 d350 extra cab 5 speed dually.
Mods: hx35,rotated fuel pin,bosch 190 inj.,BHAF with smooth intake tube,3200 rpm spring,M&H dynamic timing spacer,isspro EGT and boost gauge,Auto meter tach, fuel press. gauge.Diamond eye 4" exhaust,Sno Stage 2 W/M kit.
Real trucks dont use spark plugs!
rockmike
