how many spline is the out put of a 2wd 518?
Postby Joecochrane » Tue Feb 04, 2014 1:15 pm
I have a 518 and a divorced ford np205 going in my truck. I need to build a d shaft to go between them. Need to know what the spline count is pretty sure it's 23? And what other vehicles used that same slip yoke. Gonna want the largest u joints available so I wanna steer clear of car stuff.
The driver 02 2500 ho 6 speed 2wd lil lift 35s edge cts hot some injectors and a fass
The toy 87 f350 39.5 tires 180 bus motor 727 trans maxed pump ground pin bumped timing 366 spring hx35 and a lot more in the works.
Joecochrane
Re: how many spline is the out put of a 2wd 518?
Postby txs » Tue Feb 04, 2014 6:19 pm
Any of the slipyoke 727 trannies used that same output spline.
txs
