are all 727 long tail shafts the same?
Postby Joecochrane » Fri Feb 07, 2014 12:03 pm
I removed the gearvendors off my 727. Now I need to replace the adapter with a tailshaft housing. My question is will any long tail shaft housing work ore were the diesels different.
The driver 02 2500 ho 6 speed 2wd lil lift 35s edge cts hot some injectors and a fass
The toy 87 f350 39.5 tires 180 bus motor 727 trans maxed pump ground pin bumped timing 366 spring hx35 and a lot more in the works.
Joecochrane
Re: are all 727 long tail shafts the same?
Postby simplysmn » Thu Jun 19, 2014 10:50 pm
tailshaft housing should be the same the only difference is the bell housing area
simplysmn
