Full manual 47re
Full manual 47re
Postby 1stgenpullin » Wed Feb 12, 2014 9:49 pm
I know the 47rh is the best route but we have a re laying around and I'm going to be running a full manual valve body with od and lockup on switches. I just need to know if it will be okay without any electronics with the full manual valve body.
1stgenpullin
Re: Full manual 47re
Postby dazedandconfused » Thu Feb 13, 2014 3:55 am
You will be fine since your going a full manual VB.
Postby 1stgenpullin » Thu Feb 13, 2014 7:56 am
That's what I thought, thanks. Also what are you're thoughts on just running the transgo TFOD-3 kit instead of buying a aftermarket manual valve body?
1stgenpullin
Postby dazedandconfused » Thu Feb 13, 2014 7:59 am
I have no experience with the trans go. I've driven one with a Goerend manual VB and it was nice.
Postby 1stgenpullin » Thu Feb 13, 2014 8:10 am
I was also considering taking the valvebody out of the 47re putting the TFOD-3 kit in it and then putting that valvebody in a 48re.
1stgenpullin
Postby cougar » Fri Feb 14, 2014 11:47 am
If you can get a hold of the 48RE OD unit, use that on the 47RE as well.
01 2500 "the work truck".
cougar
Postby DodgeFreak » Fri Feb 14, 2014 12:33 pm
txs wrote:Wouldn't be simple, the supply for the lockup control circuit comes off the 2-3 shift valve, that's why 518, 47rh and 47re only lockup in direct and overdrive. The 48 re will lockup in the lower gears, and the vb parts will retrofit to 47s according to one of the fliers I was reading in a tranny shop, not sure about 518s.
Might be better off using a 48re so you can use lock up in the lower gears....or retrofit the parts into the 47 manual valve body.
Return to Transmission
