Aftermarket master and slave setup
Postby JeffTheMarine » Sat Feb 15, 2014 4:24 pm
So I have an 81 Crew Cab that I am going to be putting a Cummins in soon. I know that I would need the stock setup for the factory clutch master cylinder and pedals if I want a bolt in setup. However I figured if I am to have to search for the parts that I need then I would prefer to just go with some kind of aftermarket setup that had a bleed valve on the slave cylinder.
So basically has anyone made a custom master/slave setup for their truck or does someone make a better kit to replace the factory setup?
Thanks
Jeff
1981 Dodge W250 Crew W/94 12V&NV4500+NP205
Mods: Ground #100Plate,AFC Foot ground,BHAF
1990 Dodge D250 NonIC 12V Smoke screw flush,Fuel pin turned, Star wheel bottomed -5 clicks, fuel screw in 1 extra turn
JeffTheMarine
Re: Aftermarket master and slave setup
Postby JeffTheMarine » Mon Feb 17, 2014 8:08 pm
Someone has had to have done something....
Jeff
JeffTheMarine
Postby ellis93 » Mon Feb 17, 2014 8:13 pm
Look thru here
viewtopic.php?f=32&t=13264&p=138478#p138478
This dude did something different than stock,I think.
Return to Transmission
