Truck likes to stay in overdrive
Postby tim curran » Sat Feb 15, 2014 6:19 pm
So my truck like to stay in overdrive. In the last 120k miles I have had my tranny rebuilt twice, done a tps delete kit. And adjusted my shift cables every which way.truck goes down the road good but when I come to a big hill if if I keep a constant throttle my speed will drop to around 30 and I lugging the motor if I floor it my boost will climb upto 35 psi or so. The tranny doesn't down shift it stays. In over drive. It will shift down a gear when it drops to around 25 or so but. It's annoying seems like motor has to work awful hard in overdrive. When I tow it will do this too. Two different trannnys that were adjusted by the shop that rebuilt them and they both act the same way. How do I get this old to down shift and get out of her own way! :mad:
1993 w250, 3200 RPM springs, maxed fuel screw, industrial inj. Fuel pin, Dynamite diesel 75 horse inj., ind inj stage 2 pump, 60 lbs valve springs, ARP head studs, Banks ram air intake. 4 inch diamond eye exhaust,16cm turbo housing, 60 mm comp. Housing, BD tourqe converter, billet flex plate, Banks gauges, 212hp 608 tourque, old smokey and worn out.
tim curran
Re: Truck likes to stay in overdrive
Postby The_Head » Sat Feb 15, 2014 10:08 pm
Mines the same way, I have to use the button to get it to drop out of OD.
The_Head
Postby Diesel » Mon Feb 17, 2014 6:07 am
Tim, without a tps I don't believe it will downshift out of OD. You could try installing a new tps from a 80's Chrysler for $30-40 and see if that restores downshifts. I think it will. Sounds like mechanically your trans is fine just needs the right signals now.
1991.5 D250 Intercooled A518
Diesel
Postby tim curran » Mon Feb 24, 2014 7:08 pm
So the tps delete kit may be my problem. I think a through the tps and bracket out a couple of years ago. Has anyone els had this problem with the tps delete kit. I don't remember we're I got it from. ;)
tim curran
Postby PToombs » Tue Feb 25, 2014 6:29 pm
Have you tried to adjust the TPS delete switch while driving to see if makes a difference?
