IrishChamp wrote:anyone have any first hand experience with a tight converter and hydraulic oil?
cmann250 wrote:I have an off-the-shelf Suncoast converter and I use hydraulic oil in my transmission. I originally used regular ATF because that's what I had on hand and I changed to hydraulic oil when I put on a deep pan. I'm assuming that an off-the-shelf Spec Rite is more or less the same as an off-the-shelf Suncoast converter. After the switch, the seat of the pants dyno says it pulls harder.
All I can say is it works for me. There's still no mistaking it for a lock-up trans though.
Sutter1stgen wrote:My boss's hunting rig has a suncoast "off the shelf unit". The truck has a huge ATF cooling system, and we ran out of ATF+4, so we topped it off with John Deere hygaurd. I'd say we put a little over a gallon in when we were finished. One thing I've noticed is that for as heavy as the rig, and running larger tire, the Trans seems to run a little cooler. May just be my imagination though. Lol
BC847 wrote:IrishChamp wrote:anyone have any first hand experience with a tight converter and hydraulic oil?
I run an "off the shelf" Suncoast converter that I ended up having them tighten up even more (I can't remember if I had it tightened once or twice now ). The transmission itself amounts to an A518/48RE hybrid that includes all 6-pinion all steel planets, all billet/alloy shafts, increased clutch/steel counts, etc.
With the exception of an add-on fluid filter, the ATF cooling system is stock/OEM and includes a fan assisted (thermostatically controlled) cooler. I do have a manual ball-valve on the engine coolant side of the F2F heat exchanger so I can keep the fluid as cool as is possible when racing (thicker fluid) yet still be able to heat the fluid during the winter.
I run cheap generic tractor fluid with a couple of quarts of cheap ATF+4 for the additives.
With a 800 ~ 900 rpm idle (in gear), you certainly do have to hold the brakes on level ground.
Works like a champ.
oldestof11 wrote:1) I have mine mixed
2) 8-10 qts I believe
3) I use Napa
1STGENFARMBOY wrote:I changed my fluid a couple weeks ago to the equivalent of the John Deere stuff, I pulled the line and let it pump out all that would come out before draining it, just got back from 1,600 miles in the mountains with the camper on the truck, the temps stayed low (but) I also have a deep pan and a huge cooling system, didn't really notice any change in the shifting or converter.
