1. What do I use to mount the A518 to my truck? The crossmembers are the same, and NAPA says that the overdrive transmissions use the same rubber horizontal bolt mount as the 3-speeds. So the only thing that is different is the plate that mounts to the bottom of the transmission? And that plate is entirely unique to 91.5-93 automatic trucks?
2. Overdrive first gens only have one driveshaft and no carrier bearing?
3. I bought a yoke out of a 92 first gen automatic, and then discovered that yoke has a single extra-wide spline while the transmission only has equal width splines. Suncoast says that I need to find any yoke from 1996 to present. Huh? Did they really introduce a new yoke in 1996 and still have the same thing?
