pissed
pissed
Postby 92cummins89 » Sun Jul 27, 2014 7:56 pm
finally get the getrag swapped with the nv 4500
everything was great running good till sat and it locked up on me
the guy I had rebuilt told me it had oil and it was bone dry
waitin on him to call me back no tellin wats all messed up dropped it today but didn't open It yet
sorry for the vent
92cummins89
Re: pissed
Postby fatty » Sun Jul 27, 2014 8:18 pm
If YOU installed it without oil, you really can't blame anyone else, regardless of what they told you.
Re: pissed
Postby RCCUMMINS89 » Sun Jul 27, 2014 8:28 pm
Show any signs of leakage?
Re: pissed
Postby 92cummins89 » Sun Jul 27, 2014 8:39 pm
I dis agree I made it appoint to ask him what oil he suggest to run and how much I need to fill it and said don't worry its ready to go in
there was no signs it was in for maybe a total of 3 hours of drive time
92cummins89
Re: pissed
Postby RCCUMMINS89 » Sun Jul 27, 2014 8:43 pm
If there was zero oil in it... it wouldn't even shifted right... or at all. I'd wait and see what he says for sure.
Re: pissed
Postby 92cummins89 » Sun Jul 27, 2014 8:49 pm
there was no oil anywhere I parked on concrete for the few days I drove and had a leak under the rear end but none from the trans
im just wondering what all is gonna need to be replaced I know the bearings for sure but what bout the shafts gears, wondering if the excess heat made them weaker
92cummins89
Re: pissed
Postby RCCUMMINS89 » Sun Jul 27, 2014 8:51 pm
If it literally seized from zero oil... darn near everything. It would most likely scar the shafts.
Re: pissed
Postby 92cummins89 » Sun Jul 27, 2014 9:03 pm
not sure if I should rebuild if I have to eat it or what
I knew I should have checked the oil took his word witch is my fault but dam
what would and entire rebuild cost off the top of ur head around 2gs
92cummins89
Re: pissed
Postby PToombs » Mon Jul 28, 2014 4:45 pm
Unfortunately I'm a cynic. I don't trust hardly anyone anymore and would have checked the oil for my piece of mind. I bet next time you will too. ;)
IIRC you can get a rebuilt unit someplace for about $2g's all ready to go in. Maybe it was $2500 or so. I'm sure one of the other guys who knows how to abuse the search feature can find it or remember where it was.
Re: pissed
Postby Black93 » Mon Jul 28, 2014 4:57 pm
High Impact has new ones listed for $1900.
Black93
Re: pissed
Postby dazedandconfused » Mon Jul 28, 2014 5:05 pm
The counter shaft, 1st gear and more then likely the main shaft are junk. You always double check things like that.
Re: pissed
Postby 92cummins89 » Mon Jul 28, 2014 8:13 pm
High impact ?
Wats the web page
92cummins89
Re: pissed
Postby Black93 » Tue Jul 29, 2014 5:16 am
Black93
Re: pissed
Postby dazedandconfused » Mon Aug 04, 2014 9:54 am
What did your transmission guy say?
Re: pissed
Postby 92cummins89 » Sun Oct 26, 2014 7:26 pm
Finally tore into it an looks like just the input shaft was f*** an the needle bearing behind it was melted but guess what's called the thrust bearing ? Seemed to b fine
Everything else seems to b fine I can turn the trans with no problem there's no catch no nosie no nothing
Gonna put my new 1 3/8" input shaft wit bearing, needle bearing, an thrust bearing an new seals
An roll the dice
92cummins89
