Nv 4500 2wd to 4 wd
Nv 4500 2wd to 4 wd
Postby 92cummins89 » Wed Jul 30, 2014 9:44 pm
I destroyed my nv 4500 4wd the other day
Found a nv4500 2wd with a lot of goodies
Do I have everything I need to convert the 2wd to 4 wd?
92cummins89
Re: Nv 4500 2wd to 4 wd
Postby PToombs » Thu Jul 31, 2014 5:27 pm
Should have, but pretty sure you'll need the output from the old one. Hopefully someone who has been farther into it than me will come along and answer too.
Postby CumminsPower59 » Fri Aug 01, 2014 6:49 am
You'll need a 4wd main shaft, and rear extension housing...so if both are still useable out of your old 4wd unit, just swap them over and you're good to go!
