NP241 rear seal
NP241 rear seal
Postby Tacoclaw » Sat Aug 30, 2014 5:04 pm
Alrighty, I'm swapping the NP241 from the gasser setup in place of the NP205 I'm running now. Losing a few lbs in conjunction with the lower lo-range seems like a win-win. Truck doesn't work hard enough to warrant a 205.
Problem is that the 1410 yoke from the 205 has a larger diameter than the 13xx yoke from the 241. Does anyone know a part number for the seal that fits the 241 bore and the 205 1410 yoke?
A couple hours of googling hasn't gotten me anywhere. :?
Re: NP241 rear seal
Postby bgilbert » Sat Aug 30, 2014 8:24 pm
You might get ahold of Mark Nixon. He talked about this at one time IIRC. I'm interested as I might be doing the same with my gasser puller some day.
Bill Gilbert
Re: NP241 rear seal
Postby Tacoclaw » Sun Aug 31, 2014 4:54 pm
From RCC
Josh wrote:"I have that part # somewhere if you need it. Wait... walk across the shop - Napa 21061 (Chicago Rawhide Seal the box states). I also have written on a note in this box National Seal part # 473204 (must have purchased a national seal from Advance Auto Parts for this application as well at one point) - FYI."
Return to Transmission
